volume file clone show-autodelete
Show the autodelete status for a file or LUN clone
The volume file clone show-autodelete command displays the autodelete details of a file, LUN or NVMe namespace clone. The command displays the following information about a file, LUN or NVMe namespace clone:
Vserver Name
Clone Path
Whether auto deletion of file, LUN or NVMe namespace clone is enabled
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- -vserver <vserver name>- Vserver Name
This specifies the Vserver to which the file, LUN or NVMe namespace clone belongs.
- -clone-path <text>- Clone Path
This specifies the path of the file, LUN or NVMe namespace clone.
- [-autodelete-enabled {true|false}]- Autodelete Enabled
If this parameter is true, the file, LUN or NVMe namespace clone gets automatically deleted in the 'try' or 'disrupt' mode. If the value is false, the clones get automatically deleted only in the 'destroy' mode.
The following example displays the autodelete information about a file, LUN or NVMe namespace clone.
cluster1::> volume file clone show-autodelete -vserver vs1 -clone-path /vol/v1/f1
Vserver Name: vs1
        Clone Path: /vol/v1/f1
Autodelete Enabled: true
 PDFs
PDFs
