ONTAP commands
system snmp authtrap
Enables or disables SNMP authentication traps
Use this command to either enable or disable the standard SNMP authentication failure traps.
[-authtrap <integer>] - Enables SNMP Authentication Trap
Enter the value of 1 to enable SNMP authentication failure traps. By default, SNMP authentication trap is disabled and the value is 0.
The following example demonstrates how to set the SNMP authtrap. +
cluster1::> system snmp authtrap -authtrap 1
uster1::> system snmp show
contact:
        private
        NB
authtrap:
        1
init:
        0
traphosts:
community:
Looking for answers?
Try Doc, our Gen AI Assistant.
