system snmp authtrap
PDF of this doc site
Creating your file...
Your file is ready
Enables or disables SNMP authentication traps
Use this command to either enable or disable the standard SNMP authentication failure traps.
[-authtrap <integer>]
- Enables SNMP Authentication Trap-
Enter the value of 1 to enable SNMP authentication failure traps. By default, SNMP authentication trap is disabled and the value is 0.
The following example demonstrates how to set the SNMP authtrap. +
cluster1::> system snmp authtrap -authtrap 1 uster1::> system snmp show contact: private location: NB authtrap: 1 init: 0 traphosts: - community: - -
