ONTAP commands
vserver active-directory password-change
Change the domain account password for an Active Directory account
The vserver active-directory password-change command changes the domain account password for the specified Vserver's Active Directory account.
-vserver <vserver> - Vserver
This parameter specifies the name of the Vserver associated with the Active Directory account whose domain account password you want to change.
The following example changes the password for the Active Directory account for a Vserver named vs1 .
cluster1::> vserver active-directory password-change -vserver vs1
