ONTAP commands
storage aggregate encryption show-key-id
Display encrypted aggregate information
The storage aggregate encryption show-key-id command displays the key IDs of all NAE (NetApp Aggregate Encryption) aggregates.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <text>] - Aggregate
If this parameter is specified, the command displays information only about the specific NAE (NetApp Aggregate Encryption) aggregate.
[-aggrID <UUID>] - Aggregate UUID
If this parameter is specified, the command displays the key ID of the specified NAE (NetApp Aggregate Encryption) aggregate ID.
[-keyid-index-zero <text>,…​] - 0th Index Keyid
If this parameter is specified, the command displays the 0th index key ID of NAE (NetApp Aggregate Encryption) aggregates.
