storage aggregate encryption show-key-id
Display encrypted aggregate information
The storage aggregate encryption show-key-id command displays the key IDs of all NAE (NetApp Aggregate Encryption) aggregates.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate <text>]- Aggregate-
If this parameter is specified, the command displays information only about the specific NAE (NetApp Aggregate Encryption) aggregate.
[-aggrID <UUID>]- Aggregate UUID-
If this parameter is specified, the command displays the key ID of the specified NAE (NetApp Aggregate Encryption) aggregate ID.
[-keyid-index-zero <text>,…]- 0th Index Keyid-
If this parameter is specified, the command displays the 0th index key ID of NAE (NetApp Aggregate Encryption) aggregates.
