storage firmware disk show
Display the list of disk firmware files on the given node
The storage firmware disk show
command displays the disk firmware files present on each node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the files that match the specified node name.
[-filename <text>]
- Storage Firmware File-
Selects the files that match the specified filename.
The following example displays the disk firmware files on each node:
cluster1::> storage firmware disk show Node: Node1 Disk Firmware Files ---------------------------------------- X262_SMOOST25SSX.NA06.LOD X262_SMOOST25SSX.NA06.LOD.FVF X267_SMOOST50SSX.NA06.LOD X267_SMOOST50SSX.NA06.LOD.FVF Node: Node2 Disk Firmware Files ---------------------------------------- X262_SMOOST25SSX.NA06.LOD X262_SMOOST25SSX.NA06.LOD.FVF X267_SMOOST50SSX.NA06.LOD X267_SMOOST50SSX.NA06.LOD.FVF 8 entries were displayed.
