ONTAP commands
storage firmware disk show
Display the list of disk firmware files on the given node
The storage firmware disk show command displays the disk firmware files present on each node.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the files that match the specified node name.
[-filename <text>] - Storage Firmware File
Selects the files that match the specified filename.
The following example displays the disk firmware files on each node:
cluster1::> storage firmware disk show
Node: Node1
Disk Firmware Files
                  X262_SMOOST25SSX.NA06.LOD
                  X262_SMOOST25SSX.NA06.LOD.FVF
                  X267_SMOOST50SSX.NA06.LOD
                  X267_SMOOST50SSX.NA06.LOD.FVF
Node: Node2
Disk Firmware Files
                  8 entries were displayed.
Looking for answers?
Try Doc, our Gen AI Assistant.
