storage firmware disk show
- PDF of this doc site
Creating your file...
Your file is ready
Display the list of disk firmware files on the given node
The storage firmware disk show
command displays the disk firmware files present on each node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the files that match the specified node name.
[-filename <text>]
- Storage Firmware File-
Selects the files that match the specified filename.
The following example displays the disk firmware files on each node:
cluster1::> storage firmware disk show Node: Node1 Disk Firmware Files ---------------------------------------- X262_SMOOST25SSX.NA06.LOD X262_SMOOST25SSX.NA06.LOD.FVF X267_SMOOST50SSX.NA06.LOD X267_SMOOST50SSX.NA06.LOD.FVF Node: Node2 Disk Firmware Files ---------------------------------------- X262_SMOOST25SSX.NA06.LOD X262_SMOOST25SSX.NA06.LOD.FVF X267_SMOOST50SSX.NA06.LOD X267_SMOOST50SSX.NA06.LOD.FVF 8 entries were displayed.
