event notification destination show
Display event notification destinations
The event notification destination show
command displays event notification destinations. Note: In the case of a rest-api destination type, OCSP information is not included. It’s available in security config ocsp show -app ems command.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-name <text>]
- Destination Name-
Use this optional parameter to display information of an event notification destination that has the specified name.
[-type {snmp|email|syslog|rest-api}]
- Type of Destination-
Use this optional parameter to display information of event notification destinations that have the specified destination type.
[-destination <text>,…]
- Destination-
Use this optional parameter to display information of event notification destinations that have the specified destination address. Enter multiple addresses separated by a comma.
[-server-ca-present {true|false}]
- Server CA Certificates Present?-
Use this optional parameter to display information of event notification destinations that have the specified server-ca-present value. This field indicates whether there are certificates of the server-ca type exist in the system. If not, event messages will not be sent to a rest-api type destination having an HTTPS URL.
[-certificate-authority <text>]
- Client Certificate Issuing CA-
Use this optional parameter to display information of event notification destinations that have the specified certificate authority name.
[-certificate-serial <text>]
- Client Certificate Serial Number-
Use this optional parameter to display information of event notification destinations that have the specified certificate serial number.
[-certificate-valid {true|false}]
- Client Certificate Valid?-
Use this optional parameter to display information of event notification destinations that have the specified certificate-valid value. This field indicates whether the client certificate specified by the certificate-authority and certificate-serial fields is valid. If not, and if the REST API server requires client authentication, event messages will not be sent to the server.
The following shows examples of "event notification destination show":
cluster1::> event notification destination show Name Type Destination -------------- ---------- --------------------- StorageAdminEmail email StorageAdmin@example.com StorageAdminSyslog syslog example.com snmp-traphost snmp 10.30.40.10 (from "system snmp traphost") RestApi rest-api https://rest.example.com/rest 4 entries were displayed. cluster1::> event notification destination show -type snmp -instance Destination Name: snmp-traphost Type of Destination: snmp Destination values: 10.30.40.10 (from "system snmp traphost")
