security login banner show
Display the login banner message
The security login banner show command displays the login banner.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Selects login banners that match the specified value. Use the name of the admin Vserver to specify the cluster-level login banner.
[-message <text>] - Login Banner Message
Selects login banners that match the specified value. By default, this command will not display unconfigured, or empty, login banners. To display all banners, specify `-message`* .
The following shows sample output from this command:
cluster1::> security login banner show
Message
Authorized users only!
cluster1::>
