security login banner show
Display the login banner message
The security login banner show command displays the login banner.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Selects login banners that match the specified value. Use the name of the admin Vserver to specify the cluster-level login banner.
 [-message <text>]- Login Banner Message-
Selects login banners that match the specified value. By default, this command will not display unconfigured, or empty, login banners. To display all banners, specify
-message*.
The following shows sample output from this command:
cluster1::> security login banner show Message ----------------------------------------------------------------------------- Authorized users only! cluster1::>
