system node virtual-machine disk-object-store delete
Delete the configuration of an object store
The system node virtual-machine disk-object-store delete command removes an object store container from a node’s configuration.
-node <nodename> - ONTAP Node Name
Specifies the name of the ONTAP node from which the object store container will be removed.
-object-store-name <object store name> - ONTAP Name for this Object Store Config
Specifies the name that will be used to identify the object store configuration.
[-update-partner {true|false}] - Update HA Partner
Specify this parameter when the system is running in an HA configuration.
The following example removes a container from the specified node.
cluster1::*> system node virtual-machine disk-object-store delete
                 -node node1 -object-store-name objstore1 -update-partner
