The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage failover hwassist test
PDF of this doc site
Creating your file...
Your file is ready
Test the hwassist functionality
The ` storage failover hwassist test` command tests the Hardware Assist h/w connectivity between the two nodes in a HA pair. The test result can be one of the following.
Hardware Assist is not initialized.
HW assist is not supported.
Partner is throttling alerts.
Resource is busy.
Hardware Assist h/w returned an error.
No response from partner.Timed out.
Unexpected abort.
Partner has taken over.
Interconnect is down between nodes.
Partner is not booted up yet.
-node {<nodename>|local}
- Node-
This specifies the node from which a test alert is initiated.
The following command issues a test alert from the node cluster1-01:
cluster1::> storage failover hwassist test -node cluster1-01 Info: Operation successful.
