storage failover hwassist test
Test the hwassist functionality
The ` storage failover hwassist test` command tests the Hardware Assist h/w connectivity between the two nodes in a HA pair. The test result can be one of the following.
Hardware Assist is not initialized.
HW assist is not supported.
Partner is throttling alerts.
Resource is busy.
Hardware Assist h/w returned an error.
No response from partner.Timed out.
Unexpected abort.
Partner has taken over.
Interconnect is down between nodes.
Partner is not booted up yet.
-node {<nodename>|local}
- Node-
This specifies the node from which a test alert is initiated.
The following command issues a test alert from the node cluster1-01:
cluster1::> storage failover hwassist test -node cluster1-01 Info: Operation successful.
