network bgp vserver-status show
Display Vserver BGP status
The network bgp vserver-status show command displays the per-node border gateway protocol (BGP) status for each vserver. The BGP status for a particular vserver is "up" when at least one BGP peer group supporting that vserver is able to communicate with its peer router.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
This parameter selects the BGP status that match the specified node.
 [-vserver <vserver name>]- Vserver-
This parameter selects the BGP status for specified vserver.
 [-ipv4-status {unknown|unconfigured|up|down}]- IPv4 status-
This parameter selects the BGP status that matches the specified status for IPv4 address family.
 [-ipv6-status {unknown|unconfigured|up|down}]- IPv6 status-
This parameter selects the BGP status that matches the specified status for IPv6 address family.
cluster1::> network bgp vserver-status show
    Node                vserver    IPv4 status IPv6 status
    node1               vs1        up          up
