system controller sp config show
PDF of this doc site
Creating your file...
Display the Service Processor Config Table
The system controller sp config show
command displays the following configuration information of the service processor for all nodes in the cluster:
Node name
Service processor status
Service processor firmware version
Booted firmware version
Service processor configuration status
Physical Ethernet link status of service processor
Health monitor status
To display more details, use the -instance parameter. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported.
[-fields <fieldname>,…]
Selects the field that you specify.
[-instance ]
Displays detailed configuration information of the service processor.
[-node {<nodename>|local}]
- Node-
Use this parameter to list the service processor configuration of the specific node.
[-version <text>]
- Firmware Version-
Selects the service processor configuration with the specified firmware version.
[-boot-version {primary|backup}]
- Booted Version-
Selects the service processor configuration with the specified version of the currently booted partition.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]
- Health Monitor Name-
Selects the service processor configuration with the specified monitor name.
[-sp-status {online|offline|sp-daemon-offline|node-offline|degraded|rebooting|unknown|updating}]
- SP Status-
Selects the service processor configuration with the specified status of service processor.
[-sp-config {true|false}]
- Auto Update Configured-
Selects information about the service processor with the specified configuration status of the service processor.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Status-
Selects the service processor configuration information with the specified service processor status.
[-link-status {up|down|disabled|unknown}]
- Public Link Status-
Selects the service processor configuration with the specified physical ethernet link status.
[-name <text>]
- Display Name-
Selects the service processor configuration with the specified unique name.
The example below displays configuration of the service processor in all the nodes in the cluster:
cluster1::> system controller sp config show Firmware Booted Auto Update SP Link Node Version Version Configured Status Status Status ---- -------- --------- ------------ -------- --------- ------ node1 2.2.2 primary true online up ok node2 2.2.2 primary true online up ok
The example below displays configuration of the service processor of a particular node in detail:
cluster1::> system controller sp config show -instance -node node1 Node: node1 Firmware Version: 2.2.2 Booted Version: primary Health Monitor Name: controller SP Status: online Auto Update Configured: true Status: ok Public Link Status: up Display Name: SP Config
