ONTAP 9.9.1 commands
vserver cifs home-directory modify
Modify attributes of CIFS home directories
The vserver cifs home-directory modify command modifies the CIFS home directory configuration for a CIFS server. To use the home directory option s (-is-home-dirs-access-for-admin-enabled or/and -is-home-dirs-access-for-public-enabled ), a home directory share must be configured with a dynamic share pattern preceded by a tilde(~). Valid dynamic share patterns are ~%w and %d%w. The pattern %u is not supported with the se option s .
-vserver <vserver> - Vserver
This parameter specifies the name of the CIFS server for which you want to modify the CIFS home directory configuration.
[-is-home-dirs-access-for-admin-enabled {true|false}] - Is Home Directory Access for Admin Enabled
This optional parameter specifies whether a user with Windows administrative privileges can connect to another user's home directory. The default value for this parameter is true .
[-is-home-dirs-access-for-public-enabled {true|false}] - Is Home Directory Access for Public Enabled (privilege: advanced)
This optional parameter specifies whether any user can connect to another user's home directory. The default value for this parameter is false .
The following example modifies the CIFS home directory configuration for the Vserver "vs1". It enables users with Windows administrative privileges to connect to another user's home directory , and enables any user to connect to another user's home directory .
cluster1::> vserver cifs home-directory modify -vserver vs1 -is-home-dirs-access-for-admin-enabled true
 -is-home-dirs-access-for-public-enabled true
The following example shows the usage of the share creation pattern %d%w.
cluster1::> vserver cifs share create -vserver vs1 -share-name ~%d~%w -path %d/%w -share-properties homedirectory
The following example shows the usage of the share creation pattern ~%w.
cluster1::> vserver cifs share create -vserver vs1 -share-name ~%w -path %d/%w -share-properties homedirectory
