vserver cifs home-directory modify
PDF of this doc site
Creating your file...
Modify attributes of CIFS home directories
The vserver cifs home-directory modify
command modifies the CIFS home directory configuration for a CIFS server. To use the home directory option s (-is-home-dirs-access-for-admin-enabled or/and -is-home-dirs-access-for-public-enabled ), a home directory share must be configured with a dynamic share pattern preceded by a tilde(~). Valid dynamic share patterns are ~%w and %d%w. The pattern %u is not supported with the se option s .
-vserver <vserver>
- Vserver-
This parameter specifies the name of the CIFS server for which you want to modify the CIFS home directory configuration.
[-is-home-dirs-access-for-admin-enabled {true|false}]
- Is Home Directory Access for Admin Enabled-
This optional parameter specifies whether a user with Windows administrative privileges can connect to another user's home directory. The default value for this parameter is
true
. [-is-home-dirs-access-for-public-enabled {true|false}]
- Is Home Directory Access for Public Enabled (privilege: advanced)-
This optional parameter specifies whether any user can connect to another user's home directory. The default value for this parameter is
false
The following example modifies the CIFS home directory configuration for the Vserver "vs1". It enables users with Windows administrative privileges to connect to another user's home directory , and enables any user to connect to another user's home directory .
cluster1::> vserver cifs home-directory modify -vserver vs1 -is-home-dirs-access-for-admin-enabled true -is-home-dirs-access-for-public-enabled true
The following example shows the usage of the share creation pattern %d%w.
cluster1::> vserver cifs share create -vserver vs1 -share-name ~%d~%w -path %d/%w -share-properties homedirectory
The following example shows the usage of the share creation pattern ~%w.
cluster1::> vserver cifs share create -vserver vs1 -share-name ~%w -path %d/%w -share-properties homedirectory
