storage array show
Display information about SAN-attached storage arrays.
The storage array show command displays information about arrays visible to the cluster. If no parameters are specified, the command displays the following information about all storage arrays:
Prefix
Name
Vendor
Model
Options
To display detailed information about a single array, use the `-name` parameter. The detailed view adds the following information:
Serial Number
Optimization Policy
Affinity
Errors
Path Failover Time
Extend All Path Failure Event
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-name <text>]- Name-
Selects the arrays that match this parameter value.
[-prefix <text>]- Prefix-
Abbreviation for the named array.
[-vendor <text>]- Vendor-
Array manufacturer.
[-model <text>]- Model-
Array model number.
[-options <text>]- options-
Vendor specific array settings.
[-serial-number <text>]- Serial Number-
Array product identifier.
[-max-queue-depth <integer>]- Target Port Queue Depth (privilege: advanced)-
[-lun-queue-depth <integer>]- LUN Queue Depth (privilege: advanced)-
[-optimization-policy {iALUA|eALUA|symmetric|proprietary|mixed|unknown}]- Optimization Policy-
[-affinity {none|aaa|ap|mixed|unknown}]- Affinity-
[-error-text <text>,…]- Error Text-
[-is-upgrade-pending {true|false}]- Upgrade Pending (privilege: advanced)-
[-path-failover-time <integer>]- Path Failover Time (sec)-
Use this parameter to list arrays that have path failover time set to the value you specify.
[-all-path-fail-delay <integer>]- Extend All Path Failure Event (secs)-
Use this parameter to list arrays that have the all path failure event delay set to the value you specify.
The following example displays information about all arrays.
cluster1::> storage array show
Prefix Name Vendor Model Options
HITACHI_DF600F_1 HITACHI DF600F
IBM_1722_1 IBM 1722
2 entries were displayed.
The following example displays detailed information about a specific array:
cluster1::> storage array show -name HITACHI_DF600F_1
Prefix: abc
Vendor: HITACHI
Model: DF600F
options:
Serial Number: 4291000000000000
Optimization Policy: iALUA
Affinity: aaa
Error Text:
Path Failover Timeout (sec): 30
Extend All Path Failure Event (secs): 50
