vserver cifs symlink show
Show symlink path mappings
The vserver cifs symlink show
command displays the following information about symbolic link mappings for CIFS:
Vserver
UNIX (NFS) path
The DNS name, IP address, or NetBIOS name of the CIFS server
CIFS share name
CIFS path
Whether the locality of the CIFS server is a local, free, or wide link. (A local symbolic link maps to the local CIFS share. A free symbolic link can map anywhere on the local server. A wide symbolic link maps to any CIFS share on the network. The free link option is deprecated and may be removed in a future release of Data ONTAP.)
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information about symbolic link mappings on the specified Vserver.
[-unix-path <text>]
- UNIX Path-
If you specify this parameter, the command displays information only about the symbolic link mapping that uses the specified UNIX (NFS) path.
[-share-name <Share>]
- CIFS Share-
If you specify this parameter, the command displays information only about the symbolic link mapping or mappings that use the specified CIFS share.
[-cifs-path <TextNoCase>]
- CIFS Path-
If you specify this parameter, the command displays information only about the symbolic link mapping that uses the specified CIFS path.
[-cifs-server <TextNoCase>]
- Remote NetBIOS Server Name-
If you specify this parameter, the command displays information only about the symbolic link mapping that uses the specified CIFS server.
[-locality {local|widelink}]
- Local or Wide Symlink-
If you specify this parameter, the command displays information only about the symbolic link mappings that have the specified locality.
[-home-directory {true|false}]
- Home Directory-
If you specify this parameter, the command displays information only about the symbolic link mappings that have the target share as a home directory (if true) or as a static CIFS share (if false).
The following example displays information about all symbolic link mappings for CIFS:
cluster1::> vserver cifs symlink show Vserver Unix Path CIFS Server CIFS Share CIFS Path Locality ---------- ---------- ------------------- ----------- ------------------ -------- vs1 /hr/ 192.0.2.160 HR_SHARE /mycompany/hr/ widelink vs1 /sales/ WINDATA SALES_SHARE /mycompany/sales/ local vs1 /web/ cifs.example.com WEB_SHARE /mycompany/web/ widelink 3 entries were displayed.
The following example displays information about all symbolic link mappings that are wide links:
cluster1::> vserver cifs symlink show -locality widelink Vserver Unix Path CIFS Server CIFS Share CIFS Path Locality ---------- ---------- ------------------- ----------- --------------- -------- vs1 /hr/ 192.0.2.160 HR_SHARE /mycompany/hr/ widelink vs1 /web/ cifs.example.com WEB_SHARE /mycompany/web/ widelink 2 entries were displayed.
