event notification show
Display event notifications
The event notification show command is used to display the list of existing event notifications.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-ID <integer>]- Event Notification ID
Use this parameter to display the detailed information about the notification ID you specify.
- [-filter-name <text>]- Event Filter Name
Use this parameter to display event notifications that use the filter-name you specify.
- [-destinations <text>,…]- List of Event Notification Destinations
Use this parameter to display event notifications that use the destinations you specify.
The following example displays the event notification:
cluster1::> event notification show ID Filter Name Destinations ----- ---------------- ----------------- 1 filter1 email_dest, syslog_dest, snmp-traphost
 PDFs
PDFs
