event notification show
PDF of this doc site
Creating your file...
Display event notifications
The event notification show
command is used to display the list of existing event notifications.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-ID <integer>]
- Event Notification ID-
Use this parameter to display the detailed information about the notification ID you specify.
[-filter-name <text>]
- Event Filter Name-
Use this parameter to display event notifications that use the filter-name you specify.
[-destinations <text>,…]
- List of Event Notification Destinations-
Use this parameter to display event notifications that use the destinations you specify.
[-access-control-role <text>]
- Access Control Role (privilege: advanced)-
Use this parameter to display event notifications that use the specified access control role.
The following example displays the event notification:
cluster1::> event notification show ID Filter Name Destinations ----- ---------------- ----------------- 1 filter1 email_dest, syslog_dest, snmp-traphost
