Command reference
event notification show
Display event notifications
The event notification show command is used to display the list of existing event notifications.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-ID <integer>] - Event Notification ID
Use this parameter to display the detailed information about the notification ID you specify.
[-filter-name <text>] - Event Filter Name
Use this parameter to display event notifications that use the filter-name you specify.
[-destinations <text>,…​] - List of Event Notification Destinations
Use this parameter to display event notifications that use the destinations you specify.
[-access-control-role <text>] - Access Control Role (privilege: advanced)
Use this parameter to display event notifications that use the specified access control role.
The following example displays the event notification:
cluster1::> event notification show
ID     Filter Name       Destinations
1      filter1           email_dest, syslog_dest, snmp-traphost
