system node coredump segment show
Display a list of core segments
This command displays the following information about core segments:
name of the core segment directory
time of the panic that generated the core segment
total number of core segment files
core segment file name
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
Displays the following details:
Core segment file name
Node that owns the core segment file
System ID of the node that generated the core
MD5 checksum of the compressed data of the core segment file
Name of the core segment
Total number of core segments for the core file
Timestamp of the panic that triggered the core segment
[-node {<nodename>|local}]- Node-
Selects information about the core segments on the specified node.
[-segment <text>]- Core Segment-
Selects information about the specified core segment. If segment is a directory, the command displays the information for the first core segment file. If segment is a file, the command displays the file information.
[-owner-node <text>]- Node That Owns the Core Segment File-
Selects information about the core segments owned by the specified node. This parameter should only be used in takeover mode to display information about the partner's core segments.
[-panic-system-id <integer>]- System ID of Node That Generated Core-
Selects information about the core segments that were generated when the node with the specified system ID panicked.
[-md5-data-chksum <text>]- Md5 Checksum of the Compressed Data of the Core Segment-
Selects information about the core segments whose data segment's MD5 checksum matches the specified checksum.
[-segment-name <text>]- Name of the Core Segment-
Selects information about the core segments with the specified name.
[-total-segment-count <integer>]- Number of Segments Generated-
[-panic-time <MM/DD/YYYY HH:MM:SS>]- Time of Panic That Generated Core-
Selects information about the core segments that were generated by a panic at the specified time.
[-size <text>]- Size of Core Segment (bytes)-
Selects information about the core segments that are of the specified size.
[-panic-string <text>]- Panic String of Panic That Generated Core-
Selects information about the core segments that match the specified panic string.
The example below displays the core segments on node1 .
cluster1::> system node coredump segment show -node node1
Node: node1
Segment Directory: core.118049106.2012-01-05.17_11_11
Panic Time: 1/5/2012 12:11:11
Number of Segments: 2
Segment File Name:
core.118049106.2012-01-05.17_11_11.nvram.nz
core.118049106.2012-01-05.17_11_11.ontap.nz
2 entries were displayed.
The example below displays detailed information a specific core segment file on node1 .
cluster1::> system node coredump segment show -node node1 -segment core.118049106.2012-01-05.17_11_11.ontap.nz -instance
Node: node1
Core Segment: core.118049106.2012-01-05.17_11_11.ontap.nz
Node That Owns the Core Segment File: node1
System ID of Node That Generated Core: 118049106
Md5 Checksum of the Compressed Data of the Core Segment: 1a936d805dcd4fd5f1180fa6464fdee4
Name of the Core Segment: ontap
Number of Segments Generated: 2
Time of Panic That Generated Core: 1/5/2012 12:11:11
