      security session limit create
Create default session limit
This command allows creation of a default management session limit that does not yet exist. The default limits can be overridden for specific values within each category by using advanced privilege level commands.
- -interface {cli|ontapi|rest}- Interface
The interface (CLI, ONTAPI, or REST) to which the limit applies.
- -category {application|location|request|user|vserver}- Category
The session type for this default limit. The following categories are supported: application, location, request, user, Vserver.
- -max-active-limit <integer>- Max-Active Limit
The maximum number of concurrent sessions allowed for this interface and category.
The following example illustrates creating a default limit for management sessions using the same application.
cluster1::> security session limit create -interface ontapi -category application -max-active-limit 8
