ONTAP commands
security key-manager onboard disable
Disable the Onboard Key Manager
This command disables the Onboard Key Manager associated with the admin Vserver and permanently deletes the Onboard Key Manager configuration associated with the admin Vserver.
The following example disables the Onboard Key Manager for the admin Vserver:
cluster-1::*> security key-manager  onboard disable
Warning: This command will permanently delete all keys from Onboard Key
         Manager.
Do you want to continue? {y|n}: y
