network port show
Display network port attributes
The network port show command displays information about network ports. The command output indicates any inactive links, and lists the reason for the inactive status.
Some parameters can have "administrative" and "operational" values. The administrative setting is the preferred value for that parameter, which is set when the port is created or modified. The operational value is the actual current value of that parameter. Administrative and operational settings are not shown for virtual ports, '-' will be displayed. Please see the physical port hosting the target virtual port for these values.
If the operational duplex mode and speed of a port cannot be determined (for instance, if the link is down), that port's status is listed as undef , meaning undefined. This is different from '-', meaning no value.
[-fields <fieldname>,…] -
If you specify the
[-health ] -
Use this parameter to display detailed health information for the specified network ports.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the network ports that match this parameter value. Use this parameter with the
-portparameter to select a port. [-port {<netport>|<ifgrp>}]- Port-
Selects the network ports that match this parameter value. If you do not use this parameter, the command displays information about all network ports.
[-link {off|up|down}]- Link-
[-mtu <integer>]- MTU-
[-autonegotiate-admin {true|false}]- Auto-Negotiation Administrative-
[-autonegotiate-oper {true|false}]- Auto-Negotiation Operational-
[-duplex-admin {auto|half|full}]- Duplex Mode Administrative-
[-duplex-oper {auto|half|full}]- Duplex Mode Operational-
[-speed-admin {auto|10|100|1000|10000|100000|40000|25000}]- Speed Administrative-
[-speed-oper {auto|10|100|1000|10000|100000|40000|25000}]- Speed Operational-
[-flowcontrol-admin {none|receive|send|full}]- Flow Control Administrative-
[-flowcontrol-oper {none|receive|send|full}]- Flow Control Operational-
[-mac <MAC Address>]- MAC Address-
[-up-admin {true|false}]- Up Administrative (privilege: advanced)-
[-type {physical|if-group|vlan|vip}]- Port Type-
[-ifgrp-node <nodename>]- Interface Group Parent Node-
[-ifgrp-port {<netport>|<ifgrp>}]- Interface Group Parent Port-
[-ifgrp-distr-func {mac|ip|sequential|port}]- Distribution Function-
[-ifgrp-mode {multimode|multimode_lacp|singlemode}]- Create Policy-
[-vlan-node <nodename>]- Parent VLAN Node-
[-vlan-port {<netport>|<ifgrp>}]- Parent VLAN Port-
[-vlan-tag <integer>]- VLAN Tag-
[-remote-device-id <text>]- Remote Device ID-
[-ipspace <IPspace>]- IPspace Name-
Use this parameter to display information only about the ports that match the IPspace you specify.
[-broadcast-domain <Broadcast Domain>]- Broadcast Domain-
Use this parameter to display information only about the ports that match the broadcast-domain you specify.
[-mtu-admin <integer>]- MTU Administrative-
[-health-status {healthy|degraded}]- Port Health Status-
Use this parameter to display information only about the ports that match the health-status you specify.
[-ignore-health-status {true|false}]- Ignore Port Health Status-
Use this parameter to display information only about the ports that match the ignore-health-status you specify.
[-health-degraded-reasons {l2-reachability|link-flapping|crc-errors|vswitch-link}]- Port Health Degraded Reasons-
Use this parameter to display information only about the ports that match the degraded-reason you specify.
[-vm-network-name <text>]- Virtual Machine Network Name-
Use this parameter to display information only about the ports that match the network name you specify. Google Cloud Platform only.
The following example displays information about all network ports.
cluster1::> network port show
Node: node1
Ignore
Speed(Mbps) Health Health
Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status
e0a Cluster Cluster up 9000 auto/1000 healthy false
e0b Cluster Cluster up 9000 auto/1000 healthy false
e0c Default Default up 1500 auto/1000 degraded false
e0d Default Default up 1500 auto/1000 degraded true
Node: node2
Ignore
e0c Default Default up 1500 auto/1000 healthy false
e0d Default Default up 1500 auto/1000 healthy false
8 entries were displayed.
The following example displays health information about all network ports.
cluster1::> network port show -health
Ignore
Health Health
Node Port Link Status Status Degraded Reasons
node1
e0a up healthy false -
e0b up healthy false -
e0c up degraded false l2_reachability,
link_flapping
e0d up degraded false l2_reachability
node2
e0c up healthy false -
e0d up degraded false -
