ONTAP commands
network port show
Display network port attributes
The network port show command displays information about network ports. The command output indicates any inactive links, and lists the reason for the inactive status.
Some parameters can have "administrative" and "operational" values. The administrative setting is the preferred value for that parameter, which is set when the port is created or modified. The operational value is the actual current value of that parameter. Administrative and operational settings are not shown for virtual ports, '-' will be displayed. See the physical port hosting the target virtual port for these values.
If the operational duplex mode and speed of a port cannot be determined (for instance, if the link is down), that port's status is listed as undef , meaning undefined. This is different from '-', meaning no value.
{ [-fields <fieldname>,…​]
| [-health ]
Use this parameter to display detailed health information for the specified network ports.
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the network ports that match this parameter value. Use this parameter with the -port parameter to select a port.
[-port {<netport>|<ifgrp>}] - Port
Selects the network ports that match this parameter value. If you do not use this parameter, the command displays information about all network ports.
[-link {off|up|down}] - Link
[-mtu <integer>] - MTU
[-autonegotiate-admin {true|false}] - Auto-Negotiation Administrative
[-autonegotiate-oper {true|false}] - Auto-Negotiation Operational
[-duplex-admin {auto|half|full}] - Duplex Mode Administrative
[-duplex-oper {auto|half|full}] - Duplex Mode Operational
[-speed-admin {auto|10|100}] - Speed Administrative
[-speed-oper {auto|10|100}] - Speed Operational
[-flowcontrol-admin {none|receive|send|full|pfc}] - Flow Control Administrative
[-flowcontrol-oper {none|receive|send|full|pfc}] - Flow Control Operational
[-mac <MAC Address>] - MAC Address
[-up-admin {true|false}] - Up Administrative (privilege: advanced)
[-type {physical|if-group|vlan|vip|pvlan}] - Port Type
[-ifgrp-node <nodename>] - Interface Group Parent Node
[-ifgrp-port {<netport>|<ifgrp>}] - Interface Group Parent Port
[-ifgrp-distr-func {mac|ip|sequential|port}] - Distribution Function
[-ifgrp-mode {multimode|multimode_lacp|singlemode}] - Create Policy
[-vlan-node <nodename>] - Parent VLAN Node
[-vlan-port {<netport>|<ifgrp>}] - Parent VLAN Port
[-vlan-tag <integer>] - VLAN Tag
[-remote-device-id <text>] - Remote Device ID
[-ipspace <IPspace>] - IPspace Name
Use this parameter to display information only about the ports that match the IPspace you specify.
[-broadcast-domain <Broadcast Domain>] - Broadcast Domain
Use this parameter to display information only about the ports that match the broadcast-domain you specify.
[-mtu-admin <integer>] - MTU Administrative
[-health-status {healthy|degraded}] - Port Health Status
Use this parameter to display information only about the ports that match the health-status you specify.
[-ignore-health-status {true|false}] - Ignore Port Health Status
Use this parameter to display information only about the ports that match the ignore-health-status you specify.
[-health-degraded-reasons {l2-reachability|link-flapping|crc-errors|vswitch-link}] - Port Health Degraded Reasons
Use this parameter to display information only about the ports that match the degraded-reason you specify.
[-vm-network-name <text>] - Virtual Machine Network Name
Use this parameter to display information only about the ports that match the network name you specify. Google Cloud Platform only.
[-rdma-protocols <roce>,…​] - Supported RDMA Protocols
Use this parameter to display information only about the ports that support the specified RDMA protocols.
[-pfc-queues-admin <integer>,…​] - List of PFC Queues Administrative
[-pfc-queues-oper <integer>,…​] - List of PFC Queues Operational
The following example displays information about all network ports.
cluster1::> network port show
Node: node1
        Ignore
                                                  Speed(Mbps) Health   Health
Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
e0a       Cluster      Cluster          up   9000  auto/1000  healthy  false
e0b       Cluster      Cluster          up   9000  auto/1000  healthy  false
e0c       Default      Default          up   1500  auto/1000  degraded false
e0d       Default      Default          up   1500  auto/1000  degraded true
Node: node2
        Ignore
e0c       Default      Default          up   1500  auto/1000  healthy  false
e0d       Default      Default          up   1500  auto/1000  healthy  false
8 entries were displayed.
The following example displays health information about all network ports.
cluster1::> network port show -health
                                   Ignore
                          Health   Health
Node       Port      Link Status   Status Degraded Reasons
node1
           e0a       up   healthy  false  -
           e0b       up   healthy  false  -
           e0c       up   degraded false  l2_reachability,
                                          link_flapping
           e0d       up   degraded false  l2_reachability
node2
           e0c       up   healthy  false  -
           e0d       up   degraded false  -
