ONTAP commands
system bridge coredump show
Display a list of bridge coredumps
The system bridge coredump show command displays information about all the coredump files previously retrieved with the system bridge coredump collect command. If no parameters are specified, the default command displays the following information about the coredump files:
  • Bridge Name
  • Bridge Serial Number
  • Coredump Filename
  • Located on Node
  • Panic Timestamp
  • Panic String
To display detailed information about a single coredump file, use the -node and -corename parameters.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-serial-number <text>] - Bridge Serial Number
Use this parameter to select the coredump files from the bridge that matches the specified bridge serial number.
[-corename <text>] - Coredump Filename
Use this parameter to select the coredump files that matches the specified file name.
[-name <text>] - Bridge Name
Use this parameter to select the coredump files from the bridge that matches the specified bridge name.
[-node <nodename>] - Located on Node
Use this parameter to select the coredump the coredump files that are located on the specified node.
[-panic-time <MM/DD/YYYY HH:MM:SS>] - Panic Timestamp
Use this parameter to select the coredump files that were collected at the specified time.
[-panic-string <text>] - Panic String
Use this parameter to select the coredump files that matches the specified panic string.
The following example displays information about all coredump files:
cluster1::> system bridge coredump show
Bridge Name: ATTO_FibreBridge7500N_1
Bridge Serial Number: FB7500N100018
   Coredump Filename: core.FB7500N100018.1970-01-05.17_50_30.mem
     Located on Node: stg-8020-6a
     Panic Timestamp: 7/6/2017 11:03:37
        Panic String: CoreDumpGenerate CLI Command
cluster1::>
