system bridge coredump show
Display a list of bridge coredumps
The system bridge coredump show
command displays information about all the coredump files previously retrieved with the system bridge coredump collect command. If no parameters are specified, the default command displays the following information about the coredump files:
Bridge Name
Bridge Serial Number
Coredump Filename
Located on Node
Panic Timestamp
Panic String
To display detailed information about a single coredump file, use the -node
and -corename
parameters.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-serial-number <text>]
- Bridge Serial Number-
Use this parameter to select the coredump files from the bridge that matches the specified bridge serial number.
[-corename <text>]
- Coredump Filename-
Use this parameter to select the coredump files that matches the specified file name.
[-name <text>]
- Bridge Name-
Use this parameter to select the coredump files from the bridge that matches the specified bridge name.
[-node <nodename>]
- Located on Node-
Use this parameter to select the coredump the coredump files that are located on the specified node.
[-panic-time <MM/DD/YYYY HH:MM:SS>]
- Panic Timestamp-
Use this parameter to select the coredump files that were collected at the specified time.
[-panic-string <text>]
- Panic String-
Use this parameter to select the coredump files that matches the specified panic string.
The following example displays information about all coredump files:
cluster1::> system bridge coredump show Bridge Name: ATTO_FibreBridge7500N_1 Bridge Serial Number: FB7500N100018 Coredump Filename: core.FB7500N100018.1970-01-05.17_50_30.mem Located on Node: stg-8020-6a Panic Timestamp: 7/6/2017 11:03:37 Panic String: CoreDumpGenerate CLI Command cluster1::>
