      volume file async-delete cancel
Cancel an async directory delete job
The volume file async-delete cancel command cancels an async delete of a directory.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume containing the directory resides.
 -volume <volume name>- Volume Name (privilege: advanced)-
This specifies the name of the volume.
 -jobid <text>- Job ID (privilege: advanced)-
This specifies the Job ID of the async directory delete job to cancel. Run volume file async-delete show to get the job ID.
The following example cancels a job with job ID "0:1" in volume "vol1" in Vserver "vs1".
cluster1::*> volume file async-delete cancel -vserver vs1 -volume vol1 -jobid 0:1
