The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume file async-delete cancel
PDF of this doc site
Creating your file...
Your file is ready
Cancel an async directory delete job
The volume file async-delete cancel
command cancels an async delete of a directory.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume containing the directory resides.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the name of the volume.
-jobid <text>
- Job ID (privilege: advanced)-
This specifies the Job ID of the async directory delete job to cancel. Run volume file async-delete show to get the job ID.
The following example cancels a job with job ID "0:1" in volume "vol1" in Vserver "vs1".
cluster1::*> volume file async-delete cancel -vserver vs1 -volume vol1 -jobid 0:1
