The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun copy pause
PDF of this doc site
Creating your file...
Your file is ready
Pause an ongoing LUN copy operation
The lun copy pause
command pauses an ongoing copy operation. Use the lun copy resume command to resume the copy operation.
-vserver <Vserver Name>
- Vserver Name -
Specifies the name of the Vserver that will host the destination LUN.
-destination-path <path>
- Destination Path-
Specifies the full path to the new LUN, in the format /vol/<volume>[/<qtree>]/<lun>.
cluster1::> lun copy pause -vserver vs1 -destination-path /vol/vol2/lun2
Pauses the ongoing copy operation identified by Vserver vs1
and destination path /vol/vol2/lun2
