job resume
PDF of this doc site
Creating your file...
Your file is ready
Resume a job
-id <integer>
- Job ID-
The numeric ID of the paused job to be resumed. A job ID is a positive integer.
[-vserver <vserver name>]
- Owning Vserver-
Use this parameter to specify the name of the Vserver that owns the job.
The following example resumes the paused job that has ID 183:
cluster1::> job resume -id 183
