The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
job resume
PDF of this doc site
Creating your file...
Your file is ready
Resume a job
-id <integer>
- Job ID-
The numeric ID of the paused job to be resumed. A job ID is a positive integer.
[-vserver <vserver name>]
- Owning Vserver-
Use this parameter to specify the name of the Vserver that owns the job.
The following example resumes the paused job that has ID 183:
cluster1::> job resume -id 183
