The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nfs storepool config show
PDF of this doc site
Creating your file...
Your file is ready
Display the storepool configuration
The vserver nfs storepool config show
command displays the following NFSv4.X storepool configuration information:
Storepool limit enforce control
Blocked client TTL in seconds
The following example displays the NFSv4.x storepool configuration information.
cluster1::*> vserver nfs storepool config show Storepool Limit Enforce Control: disabled Blocked client TTL in seconds: 90000 cluster1::*>
