vserver nfs storepool config show
Display the storepool configuration
The vserver nfs storepool config show command displays the following NFSv4.X storepool configuration information:
The following example displays the NFSv4.x storepool configuration information.
cluster1::*> vserver nfs storepool config show Storepool Limit Enforce Control: disabled Blocked client TTL in seconds: 90000 cluster1::*>
