The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume reallocation on
PDF of this doc site
Creating your file...
Your file is ready
Enable reallocate jobs
Globally enables all reallocation jobs in a cluster. You must globally enable reallocation scans in the cluster before you can run a scan or schedule regular scans. Reallocation scans are disabled by default.
This command is not supported for FlexGroups or FlexGroup constituents. |
cluster1::> volume reallocation on
Globally enables all reallocation jobs on a cluster.
