volume reallocation on
Enable reallocate jobs
Globally enables all reallocation jobs in a cluster. You must globally enable reallocation scans in the cluster before you can run a scan or schedule regular scans. Reallocation scans are disabled by default.
NOTE:
This command is not supported for FlexGroup volumes or FlexGroup constituents.
cluster1::> volume reallocation on
Globally enables all reallocation jobs on a cluster.
