vserver cifs cache name-to-sid delete-all
PDF of this doc site
Creating your file...
Your file is ready
Delete all the entries for the vserver
The vserver cifs cache name-to-sid delete-all
command removes all of the Windows user cache entries cached by the Windows name for the specified Vserver.
-vserver <vserver name>
- Vserver (privilege: advanced)-
Use this parameter to specify the Vserver for which the name-to-sid cache entries need to be deleted.
The following example shows how to delete all of the cached name-to-sid entries for Vserver vs0:
cluster1::> vserver cifs cache name-to-sid delete-all -vserver vs0
