The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system switch ethernet log setup-password
PDF of this doc site
Creating your file...
Your file is ready
Obtain Ethernet switch admin passwords.
The system switch ethernet log setup-password
command allows the administrator to set up Ethernet switch health monitor access to certain Ethernet switches, so that switch logs can be collected.
cluster1::> system switch ethernet log setup-password Enter the switch name: (use full name from system switch ethernet show) Enter the password: (Enter admin password of switch) Enter the password again: (Enter admin password of switch) cluster1::>
Enables setup of switch log collection for the specified Ethernet switch.
