Command reference
system switch ethernet log setup-password
Obtain Ethernet switch admin passwords.
The system switch ethernet log setup-password command allows the administrator to set up Ethernet switch health monitor access to certain Ethernet switches, so that switch logs can be collected.
cluster1::> system switch ethernet log setup-password
            Enter the switch name: (use full name from system switch ethernet show)
            Enter the password: (Enter admin password of switch)
            Enter the password again: (Enter admin password of switch)
    cluster1::>
Enables setup of switch log collection for the specified Ethernet switch.
