The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
qos settings throughput-floors-v2
PDF of this doc site
Creating your file...
Your file is ready
Enable/Disable throughput floors v2 on AFF
The qos settings throughput-floors-v2
command is used to enable or disable floors v2 on AFF. The default is enabled. With floors v2 enabled, throughput floors can be met when controllers are heavily utilized at the expense of higher latency on other workloads. Floors v2 applies to both QoS and Adaptive QoS.
-enable {true|false}
- enable or disable throughput floors v2 on AFF (privilege: advanced)-
This specifies if floors v2 is enabled or disabled. If this parameter is specified with
false
floors v2 will be disabled.
The following example disables floors v2 on AFF.
cluster1::*> qos settings throughput-floors-v2 -enable false
