ONTAP commands
volume snapshot policy show
Show snapshot policies
The volume snapshot policy show command displays the following information about Snapshot policies:
  • Vserver name
  • Snapshot policy name
  • Number of schedules in the policy
  • Comment for the policy
  • Individual schedule names
  • Maximum number of Snapshot copies associated with each schedule
  • Snapshot copy name prefixes for the schedules
  • SnapMirror Labels associated with the schedules
{ [-fields <fieldname>,…​]
| [-revert-incompatible ] (privilege: advanced)
If this parameter is specified, the command displays Snapshot policies that are not supported in Data ONTAP 8.2. The total Snapshot copy count in the policy needs to be reduced to be equal to or less than the supported count for the revert operation to succeed.
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If this parameter is specified, the command displays Snapshot policies on the specified Vserver.
[-policy <snapshot policy>] - Snapshot Policy Name
If this parameter is specified, the command displays detailed information about the specified Snapshot policy.
[-enabled {true|false}] - Snapshot Policy Enabled
If this parameter is specified, the command displays detailed information only about the Snapshot policy or policies that have the specified enabled value.
[-comment <text>] - Comment
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified comment.
[-total-schedules <integer>] - Total Number of Schedules in This Policy
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified total number of schedules.
[-schedules <text>,…​] - Schedule Name
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified list of schedules.
[-counts <integer>,…​] - Maximum Snapshots for the Schedule
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified list of maximum numbers of Snapshot copies per schedule.
[-prefixes <text>,…​] - Prefix Name
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified list of prefixes.
[-snapmirror-labels <text>,…​] - Label for SnapMirror Operations
If this parameter is specified, the command displays information only about the Snapshot policies that have the specified SnapMirror Label. When you specify a list of SnapMirror labels, the command displays all the Snapshot policies that contain any of the SnapMirror Labels specified in the list.
[-policy-owner <text>] - Owner of the policy
If this parameter is specified, the command displays information only about the Snapshot policies that have the specified policy owner.
[-total-count <integer>] - Total Number of Snapshots in This Policy
If this parameter is specified, the command displays information only about the Snapshot policies that have the specified total number of Snapshot copies.
[-retention-periods <snaplock minmax period>,…​] - SnapLock Retention Period
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified retention-period set.
The following example displays information about all Snapshot policies:
cluster1::> volume snapshot policy show
Vserver: cm
                         Number of Is
Policy Name              Schedules Enabled Comment
default                          3 false   Default policy with hourly, daily  weekly schedules.
    Schedule               Count     Prefix                 SnapMirror Label
    hourly                     6     hourly                 -
    daily                      2     daily                  -
    weekly                     2     weekly                 -
default-1weekly                  3 false   Default policy with 6 hourly, 2 daily  1 weekly schedule.
    hourly                     6     hourly                 -
    daily                      2     daily                  -
    weekly                     1     weekly                 -
none                             0 false   Policy for no automatic snapshots.
Vserver: vs0
                         Number of Is
p1                               1 false   -
    weekly                     2     weekly                 -
p2                               2 true    -
    hourly                     6     hourly                 -
    daily                      2     daily                  -
5 entries were displayed.
