volume snapshot policy show
Show snapshot policies
The volume snapshot policy show command displays the following information about Snapshot policies:
Vserver name
Snapshot policy name
Number of schedules in the policy
Comment for the policy
Individual schedule names
Maximum number of Snapshot copies associated with each schedule
Snapshot copy name prefixes for the schedules
SnapMirror Labels associated with the schedules
[-fields <fieldname>,…] -
If you specify the
[-revert-incompatible ](privilege: advanced) -
If this parameter is specified, the command displays Snapshot policies that are not supported in Data ONTAP 8.2. The total Snapshot copy count in the policy needs to be reduced to be equal to or less than the supported count for the revert operation to succeed.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If this parameter is specified, the command displays Snapshot policies on the specified Vserver.
[-policy <snapshot policy>]- Snapshot Policy Name-
If this parameter is specified, the command displays detailed information about the specified Snapshot policy.
[-enabled {true|false}]- Snapshot Policy Enabled-
If this parameter is specified, the command displays detailed information only about the Snapshot policy or policies that have the specified enabled value.
[-comment <text>]- Comment-
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified comment.
[-total-schedules <integer>]- Total Number of Schedules in This Policy-
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified total number of schedules.
[-schedules <text>,…]- Schedule Name-
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified list of schedules.
[-counts <integer>,…]- Maximum Snapshots for the Schedule-
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified list of maximum numbers of Snapshot copies per schedule.
[-prefixes <text>,…]- Prefix Name-
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified list of prefixes.
[-snapmirror-labels <text>,…]- Label for SnapMirror Operations-
If this parameter is specified, the command displays information only about the Snapshot policies that have the specified SnapMirror Label. When you specify a list of SnapMirror labels, the command displays all the Snapshot policies that contain any of the SnapMirror Labels specified in the list.
[-policy-owner <text>]- Owner of the policy-
If this parameter is specified, the command displays information only about the Snapshot policies that have the specified policy owner.
[-total-count <integer>]- Total Number of Snapshots in This Policy-
If this parameter is specified, the command displays information only about the Snapshot policies that have the specified total number of Snapshot copies.
[-retention-periods <snaplock minmax period>,…]- SnapLock Retention Period-
If this parameter is specified, the command displays information only about the Snapshot policy or policies that have the specified retention-period set.
The following example displays information about all Snapshot policies:
cluster1::> volume snapshot policy show
Vserver: cm
Number of Is
Policy Name Schedules Enabled Comment
default 3 false Default policy with hourly, daily weekly schedules.
Schedule Count Prefix SnapMirror Label
hourly 6 hourly -
daily 2 daily -
weekly 2 weekly -
default-1weekly 3 false Default policy with 6 hourly, 2 daily 1 weekly schedule.
hourly 6 hourly -
daily 2 daily -
weekly 1 weekly -
none 0 false Policy for no automatic snapshots.
Vserver: vs0
Number of Is
p1 1 false -
weekly 2 weekly -
p2 2 true -
hourly 6 hourly -
daily 2 daily -
5 entries were displayed.
