ONTAP 9.13.1 commands
vserver cifs domain preferred-dc check
Display validation status of the Preferred-DC configuration
Use the vserver cifs domain preferred-dc check command to check the status of configured preferred DC on a particular vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
-vserver <vserver> - Vserver
Use this parameter to specify the Vserver whose preferred DC needs to be validated.
[-server-ip <text>,…​] - DC Address
Use this parameter to display IP-address of the configured CIFS Preferred-DC servers.
[-domain <TextNoCase>,…​] - Domain Name
Use this parameter to display Domain name of the configured CIFS Preferred-DCs.
[-status {down|up}] - DC Status
Use this parameter to display information only about CIFS Preferred-DC servers with a status that matches the value you specify.
[-status-details <text>,…​] - Status Details
Use this parameter to display information only about CIFS Preferred-DC servers with status details that match the value you specify.
The following example checks the connectivity of preferred DC on vserver vs0.
cluster1::> vserver cifs domain preferred-dc check -vserver vs0
Vserver : vs0
Domain Name             DC Address         Status       Status Details
example.com             1.1.1.1             up         Response time (msec): 426
example.com             1.1.1.2             up         Response time (msec): 425
example1.com            2.2.2.2             up         Response time (msec): 423
example2.com            3.3.3.3             up         Response time (msec): 422
