      vserver audit delete
Delete audit configuration
The vserver audit delete command deletes the audit configuration for a Vserver.
- -vserver <vserver name>- Vserver
This parameter specifies the name of the Vserver associated with the audit configuration to be deleted.
- [-force <true>]- Force Delete (privilege: advanced)
This parameter is used to forcibly delete the audit configuration. By default the setting is false.
The following example deletes the audit configuration for Vserver vs1.
cluster1::> vserver audit delete -vserver vs1
 PDFs
PDFs
