vserver audit delete
Delete audit configuration
The vserver audit delete command deletes the audit configuration for a Vserver.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver associated with the audit configuration to be deleted.
[-force <true>] - Force Delete (privilege: advanced)
This parameter is used to forcibly delete the audit configuration. By default the setting is false .
The following example deletes the audit configuration for Vserver vs1.
cluster1::> vserver audit delete -vserver vs1
