statistics preset modify
- PDF of this doc site
Creating your file...
Your file is ready
Modify an existing Performance Preset
Modifies an existing performance preset configuration. The command modifies the global properties of a preset, but does not modify the details of the preset, such as specific objects and counters sampled.
-preset <text>
- Preset Name (privilege: advanced)-
Name of the performance preset to be modified.
[-new-name <text>]
- New Preset Name (privilege: advanced)-
Set preset name to the given new name.
[-comment <text>]
- Preset Description (privilege: advanced)-
Set comment to the given value.
[-privilege <PrivilegeLevel>]
- Preset Privilege Level (privilege: advanced)-
Set privilege level at which this preset can be viewed or modified to the given value. Possible values: admin, advanced, diagnostic.
cluster1::*> statistics preset show Preset Name: delta Preset UUID: 7a04f19d-02a7-11e2-8e40-123478563412 Comment: custom preset description Privilege: diagnostic Read-Only: false Archive Enabled: false Generation ID: 0 1 entry was displayed. cluster1::*> statistics preset modify -preset delta -comment "new comment" cluster1::*> statistics preset show Preset Name: delta Preset UUID: 7a04f19d-02a7-11e2-8e40-123478563412 Comment: new comment Privilege: diagnostic Read-Only: false Archive Enabled: false Generation ID: 0 1 entry was displayed.
